Ir para o conteúdo principal
Model A1419 / EMC 2806 / Late 2014 or Mid 2015. 3.3 or 3.5 GHz Core i5 or 4.0 GHz Core i7 (ID iMac15,1); EMC 2834 late 2015 / 3.3 or 3.5 GHz Core i5 or 4.0 GHz Core i7 (iMac17,1) All with Retina 5K displays
20 Perguntas Visualizar todos
Is there a SATA Cable and HDD mounting brackets already installed?
Hi,
I hope you can help me!
I recently bought a late-2015 27” iMac with a 5K display. (iMac 17,1)
The computer I bought was born with a 250GB blade SSD only – this means no SATA-HDD installed from factory.
I don’t want to open and take a look; therefore, I was hoping that someone is in the “know”.
Will there be a SATA Cable (I already ordered one, I can just sell it if there already is one inside); and will there be any HDD mounting brackets already installed?
I have just asked the seller; the computer has not undergone any upgrades since he bought it new in October 2015.
Thank you!
Rasmus
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
Pergunta mais útil
A virgin Apple iMac with a blade SSD won’t come with the SATA cable. The 27” models does come with the bracket but you will need the screws to mount the 3.5” HDD drive or the adapter frame to hold a 2.5” SSD or HDD.
I assume you are planing on adding a drive. Don’t forget to order [produto vinculado ausente ou desativado: IF174-005] as you’ll need the adhesive strips and the pizza cutter tool to remove your display. You will likely want two sets of these Plastic Cards as well.
Update (08/02/2019)
You need two stud screws and two flat head screws to hold the drive to the frame.
Here is the needed screws
iMac 27" Screw Set - Hard Drive Mount Left (x2)
iMac 27" Hard Drive Pins (x2)
If you are putting in a 2.5” drive you’ll need an adapter frame and then the screws to hold the drive to the adapter frame
Imagem de Handy tool for opening devices, spreading thermal paste, and scraping. Same as Apple Tool Part# 922-7172
Produto
Plastic Cards
$2.99
Esta resposta foi útil?
Pontuação 2
2 comentários:
Thank you, Dan :)
I’ve already got adhesive strips and the pizza cutter tool. And I have ordered a new HDD also - but I didn’t know which parts I had or had not.
To clarify, do I need 2 or 4 screws? Can you maybe link to a listing on ebay?
Thank you again, Dan :)
por
Perfect, thank you! :)
por
Adicionar a sua resposta
Rasmus Jacobsen será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 5
Duração total: 108
