Ir para o conteúdo principal
The Samsung Galaxy S9 is identified by its model number: SM-G960XU. It is the ninth generation of Samsung's Galaxy Series that was released in March 2018. Available in Lilac Purple, Midnight Black, and Coral Blue.
137 Perguntas Visualizar todos
Why my screen turned black?
So my phone fell, and the entire screen went black.
At first it was a crack, the next day the bottom half was flashing and couldn't see the bottom of my screen but this awfully strong flashing light. Then two days later it went black, and couldn't hear my phone ring or anything even tho I had charged for couple days but then I tried rebooting it (power button with lower voice button) and I will only see a thin line in the middle of the screen!
What needs to be fixed or replaced?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
3 respostas
Solução escolhida
I did it just won't turn on the whole screen only a straight line because of the crack:(
Esta resposta foi útil?
Pontuação 0
Pergunta mais útil
The screen needs to be replaced.
A local reputable repair store or an authorized Samsung Service Center (SSC) can replace the screen for you. Prices may be similar from both stores so if they are go for SSC if it is.
Pontuação 2
Most of the times this kind things happened (i mean wont responsive) because firmware crashes. You should check the Galaxy S9 troubleshooting page because there can be solution for your problem. Have you try to force restart it while connecting to the charger?
Pontuação 1
Adicionar a sua resposta
Mrs. Allabani será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 14
Duração total: 1,634
