Ir para o conteúdo principal
Model: A215-S4697 / Processor: AMD Turion 64 X2 TL-52 1.6GHz
3 Perguntas Visualizar todos
Stuck on the in touch with tomorrow Toshiba screen
I will turn on my laptop by pressing the home button and the logo with the saying “ in touch with tomorrow Toshiba”
at the bottom it says f2 for set up and f12 for boot menu. I have pressed both buttons and both seems to go to set up and boot menu but doesn’t do anything at all. I have tried taking out the battery and pressing the button down for 60 seconds and still nothing has worked .. help also found a screw in my bed could possibly fell out of my laptop from the bottom but all seemed to be fine underneath I really don’t know where it came from. I need help???
Esta é uma boa pergunta?
Pontuação 2
Adicionar um comentário
1 resposta
If you’re BIOS is working good then is must be a problem with your hard drive or the operating system, download the ISO version of your OS in another PC and make a bootable USB using Rufus, after that just boot on the USB and select the repair button.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Katalina saymiknha será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 9
Últimos 30 dias: 20
Duração total: 1,140
