Ir para o conteúdo principal
Released in 2010, the Sony Vaio SVE11B11L: also known as part of the Sony Vaio E Series. Produced by the Sony Company and is associated with other models, such as: SVE11125CXB, SVE11125CXW, SVE11135CXB, and SVE11135CXW.
9 Perguntas Visualizar todos
My laptop keeps shutting down unprompted?
My laptop, a Sony VAIO E Series 15 SVE15122CXP
(they don’t have it listed under Sony so I chose a random one.) keeps “clicking” off? Completely shutting down as if the power went out or something. Though the battery is fully charged and the charger is plugged in properly. It will turn on when I push the power button, load up, let me log in, bring up the home screen and I’ll maybe get a page on google loaded up before it clicks off once again. I’m not entirely sure what year it is, anywhere between 2010 to 2013 is when we got it.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
It must be related to your CPU temperature, I’m pretty sure that you haven’t clean the fan radiator for a while or maybe the fan is not turning at all, when your PC turns off touch the bottom surface and tell us if it’s hot or cold.
Esta resposta foi útil?
Pontuação 3
2 comentários:
It was hot as anything, didn’t even think to check the fan! I’m going to call and make an appointment at my local computer shop to have them make completely sure it’s the fan as well as service it and check everything over to make sure it’s running properly. Thank you for the helpful comment!
por
You're welcome :) .
por
Adicionar a sua resposta
Isabella DeVanney será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 24
Duração total: 2,934
