Waterproofing S3 after replacing the back cover
Will I be able to re-waterproof my S3 Frontier after replacing the back cover?
Esta é uma boa pergunta?
Yes, if you use the proper adhesives that meet or exceed the original adhesive. Your install job must be perfect or it’s water resisting abilities will be reduced or nullified.
Esta resposta foi útil?
Can i ask what adhesive ?
@Cody Tokos B7000 glue is typically used by technicians. Use this glue, clamp it tight and vacuum chamber the phone for best results.
Últimas 24 horas: 0
Últimos 7 dias: 8
Últimos 30 dias: 24
Duração total: 855
