Ir para o conteúdo principal
A versão de 2015 do smartphone de baixo custo Samsung Galaxy A3.
24 Perguntas Visualizar todos
I followed repair guides to change the battery but screen frozen
I followed your repair guide to replace the battery. I assemble the phone in reverse of the repair guide, but when I switched on, the touch screen could not scroll. I tried the soft and hard reset and all suggested methods, but still while the opening screen is on and the phone is connected to wifi etc, still touch sreen is dead. Any help pls`?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Take apart your device again and see if there is any damage to the digitizer connection flex cable. If none then reassemble and be sure you sit the cable properly onto its designated fpc connector slot.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Alfred Briffa será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 3
Duração total: 33
