Ir para o conteúdo principal
Model A1419 / EMC 2806 / Late 2014 or Mid 2015. 3.3 or 3.5 GHz Core i5 or 4.0 GHz Core i7 (ID iMac15,1); EMC 2834 late 2015 / 3.3 or 3.5 GHz Core i5 or 4.0 GHz Core i7 (iMac17,1) All with Retina 5K displays
573 Perguntas Visualizar todos
What kind of SSD is Flash Storage
Hi,
Anyone knows what kind of SSD are the 256, 512 and 1TB (not the fusion drives) Flash storage ?
Are standard SATA drives or are Blade PCIe drives ?
And if are Blades ones, are there any upgrade kit to add a second SATA SSD.
Esta é uma boa pergunta?
Pontuação 0
1 comentário
Here's a good reference on the Apple SSD drives The Ultimate Guide to Apple’s Proprietary SSDs
por
Adicionar um comentário
1 resposta
Solução escolhida
If you order an SSD only iMac you will be getting a blade SSD from Apple.
If you are buying a used system you should verify what the given system has. Go into System Report which you’ll find under the ‘About this Mac’ Look under Storage to see the drives, then open either SATA/SATA Express or NVMExpress.
Your system has two storage ports a SATA port which supports either a 3.5” or 2.5” drive and the PCIe/NVMe blade SSD port.
Here’s one possible option iMac Intel 27" (Late 2012-2019) SSD Upgrade Kit
Imagem de iMac Intel 27" (Late 2012-2019) SSD Upgrade Kit
Produto
$100.99
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
jordi será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 1
Duração total: 178
