Ir para o conteúdo principal
Unable to connect to servers
Recently bought an iPhone 6 that wouldn't turn on, the battery was the culprit and when I changed and reset it it was fine. Although when trying to put in my iCloud account it says 'verification failed can't connect to apple I'd servers.' also when I try to perform a software update it says unable to check for update, am error occured while checking for a software update
Any help troubleshooting is appreciated
Esta é uma boa pergunta?
Pontuação 0
5 comentários:
Are you trying this with your phones wifi or iTunes or both?
por
is date and time correct?
por
I actually just got an iPhone 6 with the exact same symptoms and I did the exact same thing you did.
Also tried 3UTools too. Not sure if this is an error on apple's server side at the moment.
por
Adicionar um comentário
1 resposta
Hey fellas just reading thru and notice something when i repair a 6 before, after the repair it would not connected to anything. So i went back into the phone and notice the little communication lines that run from top board to bottom board had little ground loops that the metal contact lay in. Go back into your phones fellas and see if those communication wires are into the small ground loop holders. Hope this helps. P.S. Sometimes you just have to retrace your steps.
Esta resposta foi útil?
Pontuação 0
1 comentário:
@fasttrackpro can you send a picture of the wires you are talking about
por
Adicionar a sua resposta
OneSteelTank será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 2
Duração total: 81
