Not turning on after screen replacement
I'm replacing a LCD on a Nintendo Switch that was working fine before I attempted the repair but had some spots on the backlight. After trying the new LCD, I was noticing that the backlight turned on for a second but then everything would shut off. I double checked my connections, pushed the LCD connector in as far as it would go but still got the same result. I decided to try the original LCD but got the same exact result as the replacement. Any ideas or suggestions?
Esta é uma boa pergunta?
I'm now noticing something strange. If I have only the backlight ribbon cable connected (leaving the LCD cable disconnected), the Switch turns on. But as soon as the LCD cable is connected, the Switch won't do anything. Could there be a short somehow?
por Tech Gurus
Same thing happened to me currently! I know this might be late but did you ever find an answer?
por emily sanchez
I have the same issue. I replaced the lcd connector and now the console doesn't work when the lcd is plugged in... It's really a crappy situation, since the guy who owns the switch is now threatening me.
por Tudor Baciu
