Ir para o conteúdo principal
Apple Watch Series 2, announced September 7th, 2016 and released September 16 2016.
132 Perguntas Visualizar todos
Why it's impossible to connect Apple watch and iPhone
Hello I want to know which piece is use to twinnig apple watch and iphone . It’s impossible to connect my apple watch with any Iphone . I thinks there is a piece inside who are broke can you help me please ?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
The AppleWatch connects to your iPhone over Bluetooth. There is no wired link between the two.
You will also need an Apple Watch charging base if you don’t already have one which you plug into the iPhone/iPad charger or your systems USB port to gain power.
References:
Esta resposta foi útil?
Pontuação 2
4 comentários:
the bluetooth doesn't work ! i have the magnetic charger
por
Open the AppleWatch settings > Make sure Bluetooth is enabled. Then open your iPhones Bluetooth settings does your AppleWatch show up there?
por
Yes It show on my iphone but the connection doesn't work
por
Are you using the Watch App on your iPhone?
You may need to do a hard reset Restart Apple Watch and re-join your watch to your iPhone Set up your Apple Watch
por
Adicionar a sua resposta
dossiguignan será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 72
