My HP Officejet 6600 (H711g) will not pick-up paper from the feed tray
My HP Officejet 6600 (H711g) will not pick-up paper from the feed tray. I’ve followed the instructions for cleaning the rollers. Still won’t pick-up paper.
Esta é uma boa pergunta?
3 comentários
Hi there Calvin,
I just want to get a little more information pertaining to your problem. Is the printer attempting to pick up paper (you can hear it)? Or is it not trying in general? I should be able to help if we have a little more in-depth description of the issue.
Thanks!
Austin
por Austin Lureen
The printer clicks, whines and grinds... The normal process when it's about to print. Then, after several seconds, I get the "notification" that "there is no paper in the tray".
por Calvin Carter
I cut hole in bottom of the printer and moved the little cog back in line and it works perfectly, maybe a little glue to keep it in place.
por dshaffer
