Ir para o conteúdo principal
Um console de videogame para TV produzido pela Sony Computer Entertainment; o PlayStation 4 Slim (CUH-2000 Series) é o modelo sucessor do PS4 original. Data de anúncio: 7 de setembro de 2016.
569 Perguntas Visualizar todos
PS4 Slim HDMI Filters
I recently had a ps4 slim with no signal, I swapped the hdmi port, I also had to swap a couple of HDMI filters (I dislodged and lost them) I bought some what where advertised on ebay as PS4 slim/pro HDMI filters, and although they were a little big I managed to get them in. I now have a signal but its was something like 640 x 480, it was mainly black but had a couple of colored lines up one side of the screen. I think replacing the filters would fix it but I’m having a real issue sourcing them, which is making me question if its at all possible to buy them?
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
2 respostas
Was the previous port not physically damaged? I’m thinking the problem would be caused by the HDMI encoder IC instead.
The dislodged part makes it a bit tricky as that can be caused by bad solder joints / connections behind the HDMI port pins.
Esta resposta foi útil?
Pontuação 0
1 comentário:
No damage that I could see, it was getting no signal, I swapped the port and 2 HDMI filters, the HDMI filters where sold as PS4 slim filters, these are slightly smaller and I think were falsely advertised because the one I have put in look like they have come from a standard PS4. Since the change I now do have a signal but its of a black screen (fuzzy) and a couple of colored lines.
por
I have the exact same problem. Did you ever find the correct one's for the slim?
Pontuação 0
Adicionar a sua resposta
Steve Fishwick será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 4
Últimos 30 dias: 8
Duração total: 839
