Ir para o conteúdo principal
Lançado em 4 de novembro de 2017. Modelo A1865, A1901. Disponível com GSM ou CDMA / 64 ou 256 GB / Prateado ou Cinza Espacial. (Pronunci-ase com X como número romano, isto é, iPhone X é o mesmo que “iPhone 10”.)
1200 Perguntas Visualizar todos
Why is my iPhone X showing the charging symbol but gets stuck at 2%
Hi there, yesterday my iPhone X started acting out when I plugged it into charge. My phone was on 1% so I went to charge it and it worked fine, until I left it and came back to it having only got up to 2%. I have tried restarting it and cleaning out the port (however not professionally). So I left it on charge while I was asleep and woke up this morning to it being on 2%. I unplugged it and it went to 3% and then decreased normally until it got to 1%. I am using it now not plugged in and have been for about 15 minutes, is there any way it has charged but the number hasn’t gone up? Thanks!
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
Solução escolhida
Yes, that may happen at times, power gauge doesn’t work properly because of a battery failure or a board failure. If you have used non original/certified cables or charged it with a car adapter chances of a board failure increase quite a bit. If you have a Mac or a PC available you can check battery condition with Coconut battery or 3Utools, both apps are quite accurate and can tell us more about battery status.
Esta resposta foi útil?
Pontuação 2
Adicionar a sua resposta
Rachel Adams será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 5
Duração total: 659
