Ir para o conteúdo principal
buying a new battery
Hi
So I had some water demage to my phone, everything worked but the battery wasn’t charging anymore. Everything else worked so I opended my iphone 6s up and checked with a voltage meter and my lightning port has a good voltage but my battery gives 0 volt. So I guess i have to replace the battery, where is the (cheapest) best place to buy just the battery and not the whole kit as i already have all the tools in EU (Belgium). Is there something I should look out for when buying the battery ?
Thx
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
Since you are into measuring, before buying a battery check if you have voltage at the battery connector with your multimeter, battery disconnected, it should be 3.7-4.2V. Avoid big marketplaces for battery purchase, sellers tend to disappear or change name after a while to avoid problems with customers. If you wish to buy from iFixit you can just purchase the battery+ adhesive, no need to buy the tools if you have them already.
Esta resposta foi útil?
Pontuação 2
2 comentários:
I tested the pins where the battery was supposed to be connected with when it was in the outlet, it was around 3.7-4.2 volts so the connection works, the battery however was pritty dead. Hopefully a battery replacement is gonne fix it, found one on amazon for 17 euro including shipping so even if it doesn't work out no biggie
por
@Goldppl Well, we know for sure the battery will get charge, keep fingers crossed for the rest ;)
por
Adicionar a sua resposta
Goldppl será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 1
Duração total: 24
