Ir para o conteúdo principal
Not charging and takes a while to boot
My iPhone 6 bought on eBay came without a screen which was an easy replacement but then the battery was bad so I also replaced that and after that it was working. I decided a couple of weeks later i should apply the adhesive under the battery because it was working great and i could sell it. When i went to turn the phone back on it took a long time to boot up and when it booted up the battery was at 1%. So i went to plug it in and it wouldn’t charge. So i went to go plug it into my computer and the computer didn’t recognize it in recovery mode. I have had this same exact problem on a 7 plus about a week ago and i have taken it to the apple store to try and fix it and they told me that it was on the logic board. So I decided to solder a new connector on the 7 plus and it still didn’t turn on even when connected to my computer.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
When you have both these symptoms at once, not charging a drained battery and no communication with the PC one can almost be sure the Tristar IC along the charging circuit needs to be replaced. It’s not a DIY repair and considering present used iPhone 6 prices such repair may not be economically interesting. It seems the seller packed together a bunch of faulty parts in a phone..typical for some eBay sellers..would always advice to check carefully feedbacks before purchase.
Esta resposta foi útil?
Pontuação 3
1 comentário:
I have the same issue with my customer iPhone 6 but I have replaced the tristar ic and all the Tigris ic still not working
Please I really need a solution to the issues
por
Adicionar a sua resposta
Peytron 1234 será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 1
Duração total: 110
