Ir para o conteúdo principal
Repair guides and support for all household mechanical fans including ceiling, box, tower, and stand fans.
207 Perguntas Visualizar todos
Annoying 3-speed fan issue after replacing capacitor
I’ve just replaced the capacitor on my 3-speed floor-standing fan, and while it starts and runs fine on speed 1, if you try and start it on speeds 2 or 3 it acts like the capacitor’s bad, i.e. you can hear the motor but the blades barely move and you have to spin them by hand to get them working.
If you start it on speed 1, you can then switch to speeds 2 or 3 with no problems.
Any ideas as to why it’s behaving like this?
Sure, an obvious workaround it always to start it on speed 1, but before the old capacitor started failing you could start it on any speed and it worked normally.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
Are you sure it’s an identical capacitor? The farads is the capacity,the voltage rating is the max it can handle before breaking down. For ex
20 volt cap
1,5,7,10 volts,20 volts,all good
25 volts,bad.
it could be bad or a lower capacitance than the original.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
gdubai será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 8
Últimos 30 dias: 17
Duração total: 760
