Ir para o conteúdo principal
Replacement battery boot loop.
With ifixit replacement battery in, the phone goes into a boot loop when the charging cable is plugged in. Without a cable it won’t boot at all. The Apple logo shows up for about 5 seconds and then it reboots. With the old battery back in, phone still works fine.
Bad Battery, or is there a procedure I just haven’t found or read about?
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
Solução escolhida
That’s bad luck, a faulty battery behavior matches with the one you described, you’re not supposed to do anything else besides putting it in place and use it. Ask for a replacement, they’ll send a new one.
Esta resposta foi útil?
Pontuação 2
Adicionar a sua resposta
James McCasland será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 2
Ao todo: 93
