Ir para o conteúdo principal
2.2 GHz (Turbo Boost up to 3.4 GHz), 2.5 GHz (Turbo Boost up to 3.7 GHz), or 2.8 GHz (Turbo Boost up to 4.0 GHz) quad-core Intel Core i7 processor with 6 MB shared L3 cache.
773 Perguntas Visualizar todos
Replacement battery drops from 50 to 7%
Hi All,
2 Days ago installed a new battery from Ifixit. And did the full charge and uncharge 4 times and did the SMC reset. But it seems that my battery drops from 50% to 7%.
It is going strong until the 50% mark, I can show a diagram if needed.
Anybody any clue what is going on?
Greeetings,
Valentijn
Esta é uma boa pergunta?
Pontuação 3
1 comentário:
To double check things give CoconutBattery a try to check it post a snapshot here for us to see as well Adicionar imagens a uma pergunta já existente
por
Adicionar um comentário
1 resposta
Sounds like you got a bad battery, contact iFixit for a replacement.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Valentijn van der Hammen será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 6
Duração total: 647
