Fuel in motor oil
I got old ford tractor skip loader and I replaced injectors but I'm getting fuel in my motor oil
Esta é uma boa pergunta?
The number one cause would most likely be leaking fuel injectors. ... When a fuelinjector is stuck open, the fuel will flood out. Gasoline will definitely get into the oil when this is the case. If the fuel pressure in your car is too high, that may cause gasoline to get into the engine oil.
Esta resposta foi útil?
I put new injectors how can they. Be stuck and I took them out not one was wet
There's no way it can be injectors that's why I'm asking you all
Read the rest of my answer.
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 12
Duração total: 152
