Ir para o conteúdo principal
14" - Core i3 2310M - SUSE Linux Enterprise Desktop 11 - 2 GB RAM - 500 GB HDD
18 Perguntas Visualizar todos
My power light is on but my battery light keeps blinking
My laptop fell to the ground and since then I keep seeing my power light on and my battery light blinking. The laptop was charging and was on sleep mode when it fell. Please what should I do.
Esta é uma boa pergunta?
Pontuação 1
2 comentários
Does it boot up still?
por
No, it just shows the power light and a constant blinking power light. I have tried hard reset nothing is working. I tried uncoupling the system and cleaning some areas still no show. Switched the ram stick couple of times still nothing. Don't know what to do.
por
Adicionar um comentário
1 resposta
Solução escolhida
Assuming there is no hardware damage try this:
  • Power off the laptop.
  • Take the battery out. If the battery is integrated and does not have a latch to release it then leave the battery inside the laptop.
  • Disconnected AC adapter from the laptop.
  • Press and hold the power button for at least 15 seconds.
  • Reconnect the battery and plug the AC adapter.
  • Power ON the laptop.
Esta resposta foi útil?
Pontuação 2
1 comentário:
this solution worked my laptop is ok now thank you
por
Adicionar a sua resposta
Esther Ogolo será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 7
Últimos 30 dias: 26
Duração total: 2,310
