Ir para o conteúdo principal
Lançado em 22 de setembro de 2017. Modelo A1864, A1897. Disponível como GSM ou CDMA / 64 ou 256 GB / Cores Ouro, Prata e Cinza Espacial.
678 Perguntas Visualizar todos
Replacement LCD No FRONT CAMERA DOES IT AFFECT THE REAR CAM?
Got my 8+ screen replacement NO FRONT CAMERA YET( still waiting for the replacement camera) all working good. But when I tested the REAR CAMERA it’s just BLACK. Is the BACK CAMERA AFFECTED BECAUSE THERE IS NO FRONT CAMERA INSTALLED?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
It shouldn’t be affected, as the rear camera will be conencted via a different strip to the logic board. There are two possible reasons why your rear camera has stopped working:
  1. The software/firmware for the camera only works with both cameras installed
  2. The rear camera’s connection to the board has become loose
Obviously, the first scenario is unavoidable without the front facing camera. The second can be remedied by simply reseating the camera’s connector within the phone, which should be shown here on step 8.
Hope this helps!
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
vickyong2808 será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 13
Duração total: 457
