Ir para o conteúdo principal
Also known as a multitester, or a VOM (Volt-Ohm meter), a multimeter is an electronic measuring instrument used to measure voltage, current, and resistance. Includes handheld and tabletop testing devices.
Why is my Multimeter not functioning as well in continuity mode
My Sanwa YX360TRF Analog Multimeter has malfunctioned!
I had set the dial to 750VAC and I tested it on a 220VAC power supply and I heard a mini-explosion inside the tester.
I replaced its battery and fuse after it had blown. Now it gives me false readings.
Esta é uma boa pergunta?
Pontuação 0
1 comentário:
Adicionar um comentário
1 resposta
Sadly, it does sound like your meter has become damaged internally. As much as I like analog meters they just don’t hold up as well as a digital unit.
I think its time to upgrade to a digital meter ;-}
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Laurence será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 2
Ao todo: 712
