Ir para o conteúdo principal
The March 2015 update of Apple's 13" MacBook Pro Retina Display, model A1502, features fifth-generation Intel Core i5 and i7 processors and introduces the Force Touch trackpad.
1185 Perguntas Visualizar todos
MacBook a1502 early 2015no power
My macbook suddenly died mag safe turn green then orange sometimes fan spin , cpu gets little hot , mouse clicks and usb powers on usb mouse so i was wondering if any one had any idea on what to try since the macbook won’t even chime
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
Try resetting SMC and PRAM, that’s about all you can do. CPU should be alive if mouse is powered on. If you do get back the boot chime but screen stays black try plugging your Mac to a screen/TV to see if you have an image there. If you have no boot chime even after resetting PRAM there’s a serious issue at board level to deal with, but that needs more indepth troubleshooting that requires tools and skills. However, it doesn’t seem to be a power issue.
Esta resposta foi útil?
Pontuação 2
2 comentários:
nop sometimes when i reset smc with the instruction that has pusingthe power button for 15 sec the fan powers in high revs do you think is a ppbus problem?
por
@carlos_15 The 10" power button pressing followed by plugging in Magsafe is a SMC bypass, the reset is done by pressing left shift+ctrl+alt+power button for 1". If it starts with first method and full speed fans there's a SMC issue.
por
Adicionar a sua resposta
carlos será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 2
Duração total: 115
