Ir para o conteúdo principal
Boot loop after battery replacement?
I could use some help. I replaced the battery and started recharging it. The screen comes on with the white background and gray apple and then the screen goes dark. It does this every six seconds or so. What did I do wrong? I assume the connector from the battery to the rest of the phone is bad? I tried to reseat it but that did not fix anything?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
Have your tried the old battery (if it still works) to see if the problem persists? You could have a bad battery.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
chris johnson será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 4
Duração total: 49
