Ir para o conteúdo principal
Lançado em 1999, sucessor do PowerMac G3 original, 300-450 MHz, 64 ou 128 MB de RAM, HD de 6 ou 12 GB
won't power on
Hello!
I am also having the same problem. I did what u suggested and nothing. I opened the computer and I noticed that 1 of the plugs P5 was not connected to anything. My question is should that part be connected and if so where? Maybe that is what is causing my G3 not to power up?
Thank you.
Edie
Esta é uma boa pergunta?
Pontuação 0
1 comentário
Please start a new question as this one has been answered and almost no one will now look at it. Thanks
por
Adicionar um comentário
1 resposta
Solução escolhida
The Plug "P5" is just another 4-Pin Molex power connector. It is used to power a secondary hard drive, and doesn't need to be connected to anything for the computer to work. If the computer isn't powering on, a bad power supply may be to blame. The PowerMac G3 Blue and White (as opposed to newer/older powermacs) uses a standard PC "ATX" power supply. You can buy these at just about any store that sells PC parts, or use an existing one if you happen to have one handy.
Esta resposta foi útil?
Pontuação 2
Adicionar a sua resposta
edith será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 10
Últimos 30 dias: 22
Ao todo: 1,527
