Ir para o conteúdo principal
Repair information for the things you might find in around the yard or patio, including BBQ grills and equipment, gardening tools, and weather stations.
20 Perguntas Visualizar todos
Yard Machine - electric grass trimmer- model MTD308P-REV
How do you wind the plastic cutting cord onto the spool of the feed mechanism? There is a spool, with 2 tracks. Each track has a hole for each track’s cord to go out of. When It breaks, you tap it to have a new length feed out, but it is sticking inside the spool.
How should we load the spool to trigger this mechanism?
Esta é uma boa pergunta?
Pontuação 0
1 comentário
This question was migrated from https://meta.ifixit.com/Answers.
por
Adicionar um comentário
2 respostas
Pergunta mais útil
Here is a repair guide for your trimmer.
https://rdt.prod.repairclinic.com/Repair...
Esta resposta foi útil?
Pontuação 1
Thanks for sharing the guide. It saves me a lot of time. By the way, which rechargeable electric string trimmers can you recommend to me? I found quite a lot of great options on https://homendgarden.com/best-cordless-s... and I've even chosen a few already. However, I would be interested in what string trimmers you use. Perhaps you will suggest something new to me. On the Internet, I found quite contradictory reviews about the string trimmers that I chose. I don't have any extra money right now and it will be sad if I bought an unsuitable string trimmer.
Pontuação 0
Adicionar a sua resposta
Jim Goad será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 124
