Ir para o conteúdo principal
This generation of Outback carried the same model codes as the Legacy Wagon: BP9 for the 2.5 liter and BPE for the 3.0-liter model.
My tail lights and tag light will not shut off.
What can I do to shut them off?
Esta é uma boa pergunta?
Pontuação 0
1 comentário
Do they stay on with the key in the off position?
por
Adicionar um comentário
2 respostas
Solução escolhida
Are you familiar with the switch on top of the steering column, between the steering wheel and the gauges? It is a forward / backward button and turns on "parking lights" mostly for legality over in the UK. Check that and make sure they're off, it's easy to hit and one that isn't common here in the states.
Esta resposta foi útil?
Pontuação 2
This has happened to me once and this was the cause! :)
Pontuação 0
Adicionar a sua resposta
costeacher65 será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 14
Ao todo: 345
