Ir para o conteúdo principal
A multi-function laptop released in 2010 by Toshiba. Can be used for leisure, business, or education.
15 Perguntas Visualizar todos
Laptop Displays Black Screen
My Toshiba Satellite has recently been having a bizarre issue that I haven’t been able to find anything about. When I press the power button, the power and battery indicator lights come on, but the laptop itself just shows a black screen. I opened it up and found that the laptop doesn’t seem to actually be turning on, as the fan isn’t even running. Prior to this, I had been having other strange issues. My laptop would inexplicably wake up from sleep mode even while closed and, only a day or two ago, would not let me sign in. The night before noticing the black display issue, the aforementioned “waking up while asleep issue occured”, and it displayed the black screen when turned on.
I’ve tried taking the battery out and unplugging it from the AC cable, I’ve tried a different AC cable, I’ve tried holding the power button down for 60 seconds and, so far, nothing has worked. Any help appreciated!
Esta é uma boa pergunta?
Pontuação 0
4 comentários:
If you plug your laptop into an external monitor and use the display change on your keyboard do you get an image?
por
I plugged the laptop into an external monitor and nothing came up.
por
Did you try to toggle the display button on your keyboard by using Fn + F5 to cycle through the different options?
por
Yes I did try that and the monitor just remained completely black
por
Adicionar um comentário
2 respostas
Its a Mother board issue, Get in contact with toshiba or a local tech.
Esta resposta foi útil?
Pontuação 0
It sounds like it could be a motherboard issue. It might be time to get a new laptop. Hopefully your hdd is okay and you can pull it out and use a this cable to extract your files.
Pontuação 0
Adicionar a sua resposta
Captain Average será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 4
Duração total: 283
