Ir para o conteúdo principal
The Apple Extended Keyboard is a USB-A extended keyboard with an aluminum body and a numeric keypad.
Need Help Placing large zero key back.
Is there a walkthrough for the Apple Wired Aluminum keyboard extended model MB110LL/A to replace the large zero key on the 10-key number side? I have tried everything and cannot figure out how to put it back on. And strangely enough there is no tutorials or videos on the internet anywhere. I really don’t want to go to the apple store for them to reattach a key.
Esta é uma boa pergunta?
Pontuação 0
1 comentário
I need help also. The answer from Dan did not help me. The cap from number 0 I cannot fix on.
por
Adicionar um comentário
1 resposta
Pergunta mais útil
Here’s a good site that offers the needed parts and the guides to put the key caps back on Aluminium USB Keyboard
Esta resposta foi útil?
Pontuação 1
4 comentários:
Thanks for your comment. I see where I can purchase parts but I do not see any tutorial in which to put the key back on. That is all I need since I already have the keys.
por
Opps! They took the guide away.
Here's a Vid that should help you Removing apple mac keyboard keys
por
Hi, this link has no answer for my extende magic keyboard. The cap for number 0 keeps falling off. I do not find any answers.
por
@norbertus - If you look carefully you’ll see the keyboard uses the same design. Order the needed key parts and give the new ones try.
Otherwise you’ll need to visit an Apple Store or authorized resellers for them to help you.
por
Adicionar a sua resposta
Frank Spalding será eternamente grato(a).
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 5
Últimos 30 dias: 21
Ao todo: 956
