Ir para o conteúdo principal
A1708/EMC 3164 — Released June 2017, this entry-level MacBook Pro retains its traditional function keys (as opposed to the OLED Touch Bar).
563 Perguntas Visualizar todos
How can I adapt this PCIe NVMe 256GB SSD?
This Macbook Pro 13” 2017 had a particularly strange drive I need to get data off. For the life of me I cannot find an enclosure or adapter for it.
Anyone seen anything like that? Or am I going to have to buy another machine to get at the data?
Esta é uma boa pergunta?
Pontuação 1
7 comentários
Can you tell us what happened, give us details we might have other alternatives.
por
Poor customer with no backup went to apple and they said of course we can fix the failed logic board but we won't back up your data. Such a crazy thing to tell your customer, this poor girl; We have to help her. So I will buy another machine from apple refurb and use it to recover the data. Then return it to them and tell them its crap.
por
@heavylabs - Did you check if the system is covered? 13-inch MacBook Pro (non Touch Bar) Solid-State Drive Service Program I forgot about that program.
por
As it turns out the drive has also failed and yes this machine is a part of the "Apple's Homemade SSD That Sucked" replacement program. This girl will lose her data now or face a very very expensive recovery.
por
Exibir mais 2 comentários
Adicionar um comentário
3 respostas
Solução escolhida
You are absolutely justified in your pain. Apple giving us no recourse to recover data is total disregard for the needs of their customers.
Please join us to help secure your rights:
https://ifixit.org/right
@kyle Is there any other recourse that you are aware of?
Esta resposta foi útil?
Pontuação 3
1 comentário:
Done! With 25 years in the tech support and sales business, 10 years ago I was sick of the wasteful attitude promoted by corporations. Each day I do my best to convince people to repair repair repair.
por
Sadly, its a custom Apple SSD! So far I don’t know of any case or adapter to support it so you can access the data on it.
But with that said! You do have one other option renting or buying another 13” MacBook Pro Fn system and carefully sliding out the SSD so you can plug yours in then using an external drive coming the data off.
Do make sure you’ve fully powered down the system before removing the SSD so you don’t damage it.
Pontuação 2
1 comentário:
Apple refurb department is about to get a return 2 days later ;) Found exact model
por
Hi,
I have a MacBook Pro 2017 (Function keys) and I had an accident (water dropping) and the screen and connections are damaged. I couldn’t find affordable fixing, so right now is broken but the SSD works.
I bought a Lenovo A340-24IWL and I’d like to know if is possible to put the SSD from my broken MacBook Pro on this Lenovo A340? Do you have some enclosure or adapter to use this SSD on a PC?
Thank you very much for your response!!!
Pontuação 0
Adicionar a sua resposta
Chris D será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 3
Últimos 30 dias: 4
Duração total: 1,382
