How to fix the washer ring without buying a new one?
I have a kenmore washer model number 11020022012 and the balancing ring has small tabs on the side that clicks into place. Those tabs are broken. How can I repair them at home??
Esta é uma boa pergunta?
Pontuação
0
Can you add a phot?. Usually those small clips can't be glued back on, because there is just not enough material for any glue to hold that force. However, if you don't want to buy a new part, you might be able to use screws to attach a home-made metal clip instead. Without a photo, I don't know if that idea is feasible.
por Klaus Martinek
