Ir para o conteúdo principal
A zipper found on clothing and gear to keep everything zipped up!
18 Perguntas Visualizar todos
The zipper end of my sweater jacket came off.
Can the metal end on the side which the slider is attached, be replaced?
It holds the other straight end of the zipper to prevent separating of the zipper.
Esta pergunta é pertinente?
Pontuação 0
1 dos comentários
Can you post some pictures?
por
Adicionar um comentário
2 respostas
Solução escolhida
Here’s how:
Repairing Zipper Slider
Here are guides for other types of zippers:
Zipper Repair
Esta resposta foi útil?
Pontuação 2
Use a small safety pin. If the little loop of the zipper end is still there you can use a small safety pin put it through the loop and close it it will work just like the zipper end that came on it.
Pontuação 1
Adicionar a sua resposta
Wendy Forselius será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 4
Duração total: 327
