Ir para o conteúdo principal
Repair information and support for walk-behind lawn mowers made by the Toro Company.
Where does the reverse hook
Where does the reverse hook fit into the handle?
Update (06/07/2019)
Where does the reverse hook fit on the handle on model 20355
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
There are 3 lines (i.e. 20, 23 and 24 in Figure below) going from the deck to the handle.
One of the lines goes to the Break Bar (i.e. 20 in Figure above; Also called the safety or control bar), and the other is the front traction cable (23 in Figure above). Both are circled in red below.
Finally, the read traction cable (24 in Figure above) is installed on the rear of the handle (circled in red below). Click on the image for a closer view.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Bev Zehren será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 16
Ao todo: 117
