Ir para o conteúdo principal
Also known as the m300, the Clip is a simple MP3 player by SanDisk released in 2007.
cannot copy musical files from the pc
Hi, my sansa clip mp3 player, once connected to the pc, cannot copy the musical files. Once done copying and pasting, seems to be copying, but the copy percentage remains at 0%.
If anyone can helps me please.
Thank you
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
I have that same MP3 player. It is a good MP3 player.
Do you have a Linux computer available? If not, then go to https://linuxmint.com/download.php and download one of the Linux distros (if you aren’t sure which, then download 32-bit Xfce). Now create a DVD from the file that you downloaded. Once you have done that, reboot the computer with the DVD in the drive, and boot to the DVD. Doing so will load a copy of Linux Live on your computer. (Nothing on your hard drive will be erased by doing this.)
Once you have logged into Linux Live, try to copy some music to your MP3 player.
The reason I suggest Linux is because sometimes Linux is better than Windows at reading and writing to a drive.
Esta resposta foi útil?
Pontuação 1
2 comentários:
I really thank you,
I haven't solved your answer but I have solved the Firmware update from 02.01.32 to 02.01.35!
He thinks I bought a Sansa Clip Sport, but it's not as powerful as the Sansa Clip!
Finally I solved, I'm very happy !!
Greetings and thanks.
Angela
por
Hi,
I'd like to ask you another question about Sansa Clip.
After the update I noticed that the volume of the songs is very low, before the Firmware update it was much higher. I read that there is the ReplayGain function, I tried to use it, but the volume always remains low.
Would you have a solution for this?
Thank you.
Angela
por
Adicionar a sua resposta
Angela será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 4
Ao todo: 502
