Ir para o conteúdo principal
Repair guides and support for riding, or ride-on, mowers, also known as lawn tractors, of all types used in tending large tracts of land.
857 Perguntas Visualizar todos
I have a general wiring question about ignition wire harness?
I am actually working on a dixon ztr 308 zero turn mower and am wondering if I have to use a wire harness to connect keyed ignition switch or if I can wire strait from ignition to solenoid, magneto, and ground? Is the harness just for a quick disconnect?
Esta é uma boa pergunta?
Pontuação 0
1 comentário
Thank you for the confirmation all the wires were corroded and direct wired now with better quality wire. Runs great now
por
Adicionar um comentário
1 resposta
Solução escolhida
A harness is for consistent easy assembly at the factory. You can direct wire with a connector or not. The ZTR 429 I’m rebuilding wouldn’t engage the blade clutch, the connector was so badly corroded. I bypassed it using wire nuts. Now waiting on new drive cones to finish the rebuild.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Wesley Neal será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 5
Últimos 30 dias: 6
Duração total: 58
