Ir para o conteúdo principal
Laptop not booting, no beeps, no fan
My HP Envy 15 Laptop (Model Number 15-ae170nz) just stopped working without any prior issues. When I try to boot it up all that happens is that the light on the power button goes on for about 5 seconds, but there are no beeps or fan noises. Previously it was working fine, I put it to sleep normally and when I tried to boot it again it was like this.
I opened it up and found a loose screw rolling around inside… I tried removing battery, ssd and RAM without any effect.
Any ideas?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
I would just check to make sure that there are no bent or messed up pins for the ram socket. I had this issue once before but on a MacBook and that fixed it up. I suggest taking a phone camera and looking closely at the pins.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Paul será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 4
Duração total: 155
