Ir para o conteúdo principal
The PlayStation 3 (or commonly known as the PS3) is the third home computer entertainment system produced by Sony Computer Entertainment, and the successor to the PlayStation 2. It was released November 11, 2006
781 Perguntas Visualizar todos
How to switch hard drive on different fat models?
I bought two broken fat ps3s off ebay, one had the broken motherboard and no display and the other one was missing a hard drive. I tried installing the hard drive from the first PS into the other one following the guide on this site but the systems have different connectors for the hard drives? The PS I took the drive out of had the connectors facing forward and the second PS had them to the left. How do I properly install the hard drive into the second PS? They are both fat models.
EDIT: The broken model I’m taking the drive from is a CECHL03 and the second is a CECHG03.
Esta é uma boa pergunta?
Pontuação 0
4 comentários
@retroadvance
post some images of those connectors etc or at least give us the data label from both of those drives. They should all be SATA drives
por
@oldturkey03 I only have one drive because the second PS3 came without one
por
@retroadvance Duh, of course you are right :-). You mentioned that in your question. Can you post some pictures of the connectors? Here is the guide on how to post images Adicionar imagens a uma pergunta já existente
por
I'm not a ps3 expert however one seems to be a 40gb version and the other an 80gb version so I'm not sure if the drives are interchangeable so without pictures that may be the problem ur having
por
Adicionar um comentário
1 resposta
Solução escolhida
I’m speaking from some pretty rusty experience, but I believe that different PS3 fat models use the same types of hard drives (2.5” SATA) but in different orientations. Some versions of the console have the drive slide in with the connectors facing the direction of insertion, while others have the drive slide in with the connector on the side. For the later, you have to slide the drive in, then over to get it to engage. The drive is supposed to mount in a caddy, which slides into the system. If the caddy is missing (which I’m guessing yours is), it’s difficult but not impossible to get a drive into one of the sideways-mounted systems. I’ve used some folded up paper to hold the drive in place once I’ve finessed it into the connector.
Esta resposta foi útil?
Pontuação 3
Adicionar a sua resposta
Dan Rafter será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 7
Últimos 30 dias: 16
Duração total: 674
