Ir para o conteúdo principal
Samsung's flagship phone, the Galaxy S8. Released in April 2017.
Mobile Network Not available
I have a circle with a line through it where there should be cellular signal strength. Have tried all the “ususal suspects”, multiple network resets, wifi calling is off, reset phone to factory defaults and even full factory reset and reload software. Tried multiple sim cards, all of which work in other phones. Phone is now apart…..all parts look in tact and fully functional. Phone seems to recognize when I install a sim card, but never gives a connection to a network. From phone firing up after complete system restore, the circle with the line is present. Any ideas?
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
Pergunta mais útil
If the phone is use, maybe is Black Listed in USA Networks, or has a wrong Sim Card.
If was working fine and stopped working, Base Band Chip may have issues, Check if you can see the IMEI Number in your Settings.
If you dropped recently may has a Internal Antenna Disconnection.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
dougal será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 14
Ao todo: 1,058
