Ir para o conteúdo principal
Repair guides and support for cars manufactured by Jaguar.
Car wont start and has a gearbox fault
Car won't start and has a gearbox fault
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Reply 23/11/2021. Get your Auto Electrician to check and replace the non conducting paste protecting the connector pins beneath the main fuse box in the engine bay near the battery. I purchased an Xtype AWD 2001 which suffered this problem and the paste had dried out and moisture was apparently causing electric crossing between the pins. This was resolved by removing and replacing this non conductive paste. I had many varied messages on dash screen with erratic dash readings. Also the gearbox is serviced in Great Britain but the Dealership centres in Australia were not draining and replacing the gearbox oils. Minor leaks can occur and when sufficient oil is lost this causes actual failure of gearbox. Dealership then replaces the gearbox at owners expense. Good Luck, Alan
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Marcia Deems será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 3
Ao todo: 303
