Ir para o conteúdo principal
Guias de reparo, técnicas e informações de desmontagem para smartphones Android fabricados pela Xiaomi.
1686 Perguntas Visualizar todos
Water damaged now my phone screen works automatically
I have redmi 5a phone . I got some water in my phone about 6 months ago but now my phone screen works automatically sometimes.when I do a screen test it shows a vertical line blinking in the lower part of the phone.
Esta é uma boa pergunta?
Pontuação 2
Adicionar um comentário
4 respostas
Pergunta mais útil
But ... changing the screen will not solve the liquid damages. You should clean it before changing any circuit or part.
Esta resposta foi útil?
Pontuação 2
1 comentário:
True and I think the best liquid to clean it with is with 99.9% alcohol
por
Try doing a screen replacement. If that doesn’t work, try checking for bad connections on the Logic-Board. If you found some, try replacing the logic board. Personally, I think that the Logic Board replacement will be obligatory since the one your using will probably have board-level water damage.
Pontuação 1
Change your screen display bro
While changing you could learn more about your phone... Please checkout link given below
https://youtu.be/4LCO5Ik6QzA
Pontuação 0
Redme 5a
switch on
Pontuação 0
Adicionar a sua resposta
Sahil sharm será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 8
Últimos 30 dias: 47
Duração total: 436
