Ir para o conteúdo principal
Will a SATA 2 HD work correctly?
I would like to know if I can change the original HD in my macbook pro first generation? I found models like western digital scorpio black or seagate ones. For example this: http://www.amazon.com/Western-Digital-WD...
thanks for the answer.
Ben
Esta é uma boa pergunta?
Pontuação 3
1 comentário
I just installed a WD sata I disk, it works fine! It is the one sold on the website
por
Adicionar um comentário
2 respostas
Solução escolhida
Yes, SATA 2 hard drives are backward compatible and will work on your machine, although they will only perform at the slower speed. iFixit also sells hard drives for your machine.
Esta resposta foi útil?
Pontuação 3
The short answer is yes. Everything works, I've even installed Vista SP2. However, I ran into a problem with my machine/HD combo that I'm still working out.
See this Question/Answer Link
Also here is my Discussion about it.
I'm currently awaiting a 5400 RPM drive from Seagate to see if that will work in my situation. I'm not sure what I'll do if it doesn't.
YMMV.
Pontuação 1
Adicionar a sua resposta
ben será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 6
Últimos 30 dias: 9
Duração total: 4,504
