Ir para o conteúdo principal
Released September 21, 2018. Models A1920, A2097, A2098, A2100. Available as GSM or CDMA / eSIM or nano-SIM / 64, 256, or 512 GB / Silver, Gold, or Space Gray. (Pronounced "iPhone 10 S.")
398 Perguntas Visualizar todos
iPhone XS does not power on but gets warm when on charge
A customer has given me an iPhone XS that has suddenly stopped powering on.
It's not in DFU/Recovery mode.
It will not show up in iTunes.
When on charge (with the cable or wireless) the phone gets warm/hot in the lower 10% of the screen so it's not completely dead.
Shall I pursue this? Is the handset still under warranty as the XS is less than a year from release date.
Thanks
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
the first thing i would try would be to open the unit and reset the battery sometimes they get stuck as long as nothing is replaced this shouldn’t effect the warranty
Esta resposta foi útil?
Pontuação 0
5 comentários:
Hi Jonathan, although Apple have said that third party repair centres won't invalidate the warranty by opening the device or even fitting third party screens I have often encountered this to be wrong.
My customers have been turned away, embarrassed because they've taken a device that's been opened.
I just wondered if there was an existing fix for this without opening it.
por
As far as I know, without opening the device and the fact it will not connect to iTunes or be recognized on the pc there's not much to be done as long as the charging port is in all the way and there is voltage going to the phone it should connect if not without opening the phone apple may be there only bet
por
Lightning port is clean and dust free and it's definitely drawing power as the lower battery cell is getting warm, almost hot.
I'll be advising they RMA the device.
Thanks again
por
Its still under its warranty period no one should have to open it and reconnect the battery, just get them to send it back or take it to apple store their bad enough with their repairs and out of warranty stuff least u can do is send them the stuff that's not the customers fault and is a definite warranty issue
por
I am having this issue. This is the only thread with this issue I could find. Anyone know how to fix?
por
Adicionar a sua resposta
David Robinson será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 5
Duração total: 806
