Ir para o conteúdo principal
GSM iPad 2 with 16, 32, or 64 GB of storage, and a Dual Core A5 Processor. Model Number A1396. Repair is complicated and requires heat and prying.
should I replace the LCD or the digitizer alone?
the case is that , the imaging of the iPad is perfectly fine, but I have this difficulty in touching when touching certain parts of the screen (ex. when I am typing a message, at some point, the point where letter A, and N located isn’t functioning at all.. i need to rotate the screen for me to type the letter A and N..) should I replace the LCD ? OR IS it ok if I only replace touch pad or digitizer? pls do give me some advice
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
The digitizer has two layers which is touch screen and glass. Replacing that part will fix the touch problem.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
French Marie Escabarte será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 2
Ao todo: 121
