Ir para o conteúdo principal
4-inch iPhone released in March 2016 with similar hardware specifications to the 6S. Available in Silver, Space Grey, Gold, or Rose Gold with 16/32/64/128 GB storage options. Model: A1662 and A1723
Random black screen after replacement.
I bought replacement screen from ifixit and just finished replacing it. Black screen randomly appears when I press the power button. The backlight still turns on and there is no other problems.
I reconnect the ribbon cables several times but the problem keeps appearing. Is it a screen problem or a replacement mistake? Which of the three ribbon cables is display cable?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
Long vertical = digitizer
Short horizontal = LCD
Short vertical = front camera
Restart the phone or unplug the battery and plug it back in to try the replacement screen or after any changes…
Try the old screen to rule out a problem with the part.
Esta resposta foi útil?
Pontuação 2
3 comentários:
Thanks for the suggestions! The old screen does not have the problem.
por
You may have a screen that will work on an iPhone 5s not on the SE some 5s screens work on the se some dont...
por
Yeah, some aftermarket 5S screens do not work on the SE. Original 5S / SE or aftermarket SE screens will work fine on the SE however.
por
Adicionar a sua resposta
Enddle será eternamente grato(a).
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 3
Últimos 30 dias: 7
Ao todo: 1,055
