Ir para o conteúdo principal
The April 2014 update of the 11" MacBook Air packs refreshed dual-core i5 and i7 Haswell processors and slightly increased battery performance.
Charger Watt Over Load?
I have a macbook air 11” early 2014 and when I use my earphones or any other earphone it doesnt make a sound but when I plug In a charger it makes a static sound. Also, i bought a keyboard and when i charge it does not work
Any solutions?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
This seems to point to a faulty I/O board where you have power input and part of audio circuitry. First thing you may want to try it’s a replacement, board and relevant connecting flat cable are relatively cheap and the job may be done on a DIY basis too. Don’t forget to disconnect battery before working on the board. Here you find a guide to help you with the job:
MacBook Air 11" Early 2014 I/O Board Replacement
Esta resposta foi útil?
Pontuação 3
Adicionar a sua resposta
Fadenix será eternamente grato(a).
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 2
Últimos 30 dias: 6
Ao todo: 117
