Ir para o conteúdo principal
Controle PS4 modelo CUH-ZCT1. Lançado em novembro de 2013 pela Sony Computer Entertainment, este controlador de seis eixos com bateria de íon de lítio de 3,7 V é simples de reparar. (NOTA: O guia de desmontagem NÃO é para este modelo)
Problems with my 2 controllers
So I’ve had both of my controllers since the release of the ps4 back in 2013. The controller i use most has a problem where i would plug it in to the ps4 to charge, then it would look up for no reason without moving the right stick. My second controller i use less, has problems where running feels sluggish, sometimes closes out of menus, and sometimes shoots my gun without me pressing R2. How can i fix these problems?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Pergunta mais útil
Seems that dirt /dust has accumulated inside the Controllers. Cleaning the interiors of the Controllers should solve the problem.
Esta resposta foi útil?
Pontuação 1
One option would be to try resetting the controller. Under the L2 button there is a small hole on the back of your controller. Using an unbent paper clip, hold the button down for about 3-5 seconds. This will reset the controller. Now plug your controller into your PS4 and re-sync it for a successful reset. If this doesn’t work, then definitely try cleaning it out to see if that resolves the issue.
Pontuação 0
Adicionar a sua resposta
Lance Beltrano será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 2
Ao todo: 101
