BIOS Not Loading on Start
Hi, I have a Compaq SR5520AN Desktop PC and when I boot it and press F10 (BIOS) it dosen’t load at all.
I have a video:
Any help appreciated
Thanks
Esta é uma boa pergunta?
I have a video:
Thanks
From your video it IS loading the BIOS. How long do you wait?
Esta resposta foi útil?
(By the way, it is solved.)
It would hang on that screen, for however long I left it on.
I had to take out the cmos and put it back in the pc.
I agee with Augustine. Looks like your HDD is dead.
It is not dead surprisingly! It has 6000+ power on hours but is not dead. By the way I managed to get it working.
SOLVED (I am the writer but I can’t get on to that account)
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 6
Duração total: 604
3 comentários
Hi @dccyt
Can your PC still start windows?
If able to boot, try updating the BIOS to latest.
Try unplugging the hard disk, cd rom does it works?
lastly if not possible, try clearing CMOS by removing the internal cr2032 battery for about 5 mins and put it back in.
por Augustine
@salmonjapan The PC Does not boot windows, but I can get it to boot a windows install USB. In that, it says that no HDD was detected. I know the port works because I plugged the cd rom into the sata port the hdd was in. The CMOS battery worked, so thanks!
por Dahcrazychicken
Hi @dccyt great to hear that you can access the computer.
Most probably if your hard disk is not detected, just change it.
I think SSD price is quite reasonable, so you can consider it for the replacement and also once the system is stable and running well, update the BIOS revision to the latest too.
Cheers
por Augustine
