Ir para o conteúdo principal
Entry level business laptop introduced by Dell in 2014. Uses Intel Haswell (4th generation) processors.
CPU max out only when plugged to HDMI
Hi,
My laptop started to slow down when it’s connected to a TV screen using HDMI. (It was working fine till a week ago).
The CPU goes to 100% for any SW I open (any browser or other app). When HDMI is unplugged everyrhing works fine.
I tried to check drivers of both Intel HD graphic and Nvidia GT 720M display adapters
Any suggestions?
Thanks in advance
Esta é uma boa pergunta?
Pontuação 1
2 comentários
Hi,
Thanks for your help!
Re-installing the drivers did the trick
por
That's good. Slightly corrupted video drivers are often a cause of "strange" problems.
por
Adicionar um comentário
1 resposta
Solução escolhida
Try this:
Does it make any difference if you boot up with the TV connected rather than plugging in HDMI after boot-up?
If that doesn’t fix it try uninstalling both graphics drivers and reinstall with latest drivers.
Let me know how it goes.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Boaz Fleishman será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 7
Ao todo: 314
