Ir para o conteúdo principal
Model A1347 with 2.4 or 2.66 GHz Core 2 Duo Processor.
76 Perguntas Visualizar todos
Power outage on my mac
i had a power outage today and my mini mac went out try to put it on not coming not start ing no light coming on nothing what could be the problem? please help dont want to lost this unit had alot of info on it thanks
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
Your info is safe on the hard drive. Use a multimeter to test the output of the wall receptacle then plug in the adapter and test it next.
All you will need is a SATA to USB adapter, then plug it into another Mac to access your data:
https://www.amazon.com/s?k=usb+to+sata+a...
Esta resposta foi útil?
Pontuação 2
4 comentários:
If you don't have a DVM a cheap outlet checker will do as well like this one: 3-Wire Receptacle Tester
Do make the effort to get a good surge suppressor or better yet a UPS once you get your system running to help protect it.
por
Okay I check all of that but still not getting Mac mini to work what is my next step to get the Mac mini to work again?
por
I would like to know how can I get this computer to work again
por
You are going to have to found out, using a multimeter where the power stops coming in.
por
Adicionar a sua resposta
Roopram Chetram será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 2
Duração total: 126
