Ir para o conteúdo principal
The Canon Rebel T6i is a popular, semi-professional grade Camera with a 24.2 MP sensor designed for any user. Also known as the EOS 750D and the EOS Kiss X8i, this guide is meant to aid in the repair of a few common problems that may occur during normal use.
Date and time doesn't save after changing battery in Canon 750d
Hi,
Each time I replace the battery in Canon 750d, a screen appears asking for a date and time. The time settings are not saved in the camera when it is without a battery. Why does this happen and how can I fix it?
Esta é uma boa pergunta?
Pontuação 0
1 comentário
Did you find the solution? I have same problem with my Canon 750D. Please help
por
Adicionar um comentário
1 resposta
Solução escolhida
Hi
Unfortunately it appears as though the camera has no inbuilt backup battery (or capacitor) to maintain the date, time and zone settings when the main battery is removed.
According to the user manual on p.43, the date, time and zone will be reset :
If the camera is stored without a battery
When the camera’s battery becomes exhausted
When the camera is exposed to below freezing temperatures for a prolonged period.
It seems that you have to put up with it doing this.
Esta resposta foi útil?
Pontuação 2
Adicionar a sua resposta
Roni Aviv será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 4
Ao todo: 1,006
